LabVIEW Interface for Arduino Discussions
How to use the serial communication instead of the USB ?
Hi everyone !
I'm using the LIFO with an arduino uno connected with an USB cable, and it works properly, but I tryed to use the serial communication (Rx and Tx pin) instead of the USB cable, and it's not working anymore.
After some seconds I received the error code 5002, unable to establish the communication with arduino, in init.vi
Maybe there are some parameters to change, but I see "serial/USB" as the same choice of communication...
My electrical connexion seems to be working, I tested it with a simple arduino program (serial.println and serial.read).
It also looks that I only can transfer an arduino program with USB connexion, and not with my serial connexion.
Best regards
(3,611 Views)
LIFA is written to use the USB cable which goes through a USB-to-TTL Serial chip on the Arduino.  As far as I know, if you bypass this chip, it will no longer show up as a COM port in your computer which is required for LIFA to work.
(3,275 Views)
Hum... That's a problem...
There is a distance of 40 meters between my computer and the arduino. As you know the maximum distance for the USB protocol is 5 meters, and 4 repeters = 20m...
Is you see any solution, I woudl be grateful
Best regards
(3,275 Views)
Accepted by Silfali
oh my god I found the solution !
It's absolutly stupid : just reset the arduino between starting LIFO and receiving the error.
I don't knew why but it's working...
Thanks Nathan_B for your time, and see you everybody
Best regards
(3,275 Views)
