LabVIEW Interface for Arduino Discussions
LabVIEW Interface for Arduino for servo motor
hi  im a newbiew to labview .... i got the arduino interface with labview using LIFA nd tested the led on/off code which works but i tried the same thing using LINX firmware but it didnt work for both arduino uno and arduino leonardo
after my led worked with the uno using LIFA firmware i tried to run a servo motor from labview using the positive 5v , ground nd pwm pins in arduino but it didnt work at all though at times i notice the rx and tx led lights on arduino lighting up ..... here with i have attached my vi
(7,503 Views)
How do you have the servo wired to the Arduino?  The signla wire should be connected to Digital pin 2.
(4,922 Views)
yes i did connect the servo to pin 2 bt doesnt work though i see the rx nd tx on arduino lighting up at certain times
(4,922 Views)
