I am receiving error code 5005 when trying to run the examples from Labview. I have the Arduino Uno/LabVIEW 2011 bundle running on Windows XP SP3. I have sucessfully installed all the Software and drivers. I have also successfully uploaded the LIFA base to the Arduino Uno. I have noticed that after installing the Arduino Uno driver, the port displays as "Communication Port (COM3)". All the installation screen captures I have seen have the port listed as "Arduino Uno (COMx)" where x is the port number.
The Arduino Uno is on COM3. MAX has verified the port without errors.
Could the COM port name "Communication Port (COM3)" be the reason for Error Code 5005? Please, I need some help.
