LabVIEW Interface for Arduino Discussions
Please Help me ! Hall effect sensor
Sorry for my ENGLISH i'm french, i have so much probleme with labview i can't read digital signial, i would like know the speed using a Hall effect sensor connect to arduino
Message 1 of 28
(16,101 Views)
someone can help me please
Message 2 of 28
(7,245 Views)
Kinsz,
You're going to have to provide a lot more details on what you are trying to do and what specific questions/problems you have.  The more we know and the more specific your questions are the easier it is for us to help you.
Thanks!
-Sam K
LIFA Developer
Message 3 of 28
(7,245 Views)
I am beginner in labview and I would like to know the speed of a car on a bench speed for this I use a hall effect sensor I want to use labview because it has a very interesting graphical interface (speedometer, graph of acceleration with respect to time).
My sensor operates all or nothing, it is a digital sensor.
Please help me.
Message 4 of 28
(7,245 Views)
hi friend, the Hall sensor is a sensor that uses the Hall effect to measure magnetic fields or currents or for the determination of position, if current flows and by a Hall sensor approaches a magnetic field flowing in vertical direction the sensor, the sensor projecting creates a voltage proportional to the product of magnetic field strength and current
These electrical units are being introduced to the arduino pin that is if we read a digital value high, sete is interpreted as the presence of a magnetic field, and if the value is under no magnetic field, ie can be connected to a digital or analog pin, if we can only play two digital high and low states, eb change if the range of analog values ​​is greater
When asked about the speed you do, you should refer to that speed the arduino communicates with the computer, Hall sensors are available in different brands either Infineon, Panasonic, etc. http://www.hobbytronics.co.uk/datasheets/A1120EUA-hall-effect-switch.pdf  andunto technical sheet
and a code for the respective tests lucky
const  int hallPin = 12;      / / pin de sensor  hall
const  int ledPin = 13;      / / pin LED
int = 0 hallState ;
void setup () {
  pinMode (ledPin, OUTPUT );
  pinMode (hallPin, ENTRADA );
void loop ()
  hallState =  digitalRead (hallPin);    / / read sensor Hall:
  If (== hallState LOW )
    digitalWrite (ledPin, HIGH );
  Else
    digitalWrite (ledPin, LOW );
Message 5 of 28
(7,245 Views)
Message 6 of 28
(7,245 Views)
It can also serve this link arduino official website, in that code transmits sensor data to the computer
http://playground.arduino.cc/Code/HallEffect
Message 7 of 28
(7,245 Views)
With Labview I want to see my sensor information to deduce the speed
Message 8 of 28
(7,245 Views)
The code ARDUINO I have to do tests but I do not like the GUI, that is why I would like to use labview
Message 9 of 28
(7,245 Views)
MY REFERENCE SENSOR: XS1-N12PA349
This is a digital sensor
Message 10 of 28
(7,245 Views)
