LabVIEW Interface for Arduino Discussions
problem with buzzer connection
hi all, i have costructed circuit to detect temperature and switch on buzzer and led when exceed the value. i connect multi sensor to the arduino. The led work well which turn on when exceed value, but the buzzer doesn;t function well. when the first sensor triggered, buzzer 1 was on, buzzer 2 and led 2 also switch on (for 1s and off again and repeatedly). can anyone know what's wrong with this circuit? your help wll be much appreciate. I also want to know whether possible to connect multi sensor to the same arduino? thank you so much.
(4,059 Views)
Your other VI (in the other discussion) is much closer to being correct.  I posted my comment there.  It is very important that you don't branch the Arduino resource and that you have all your Arduino VIs (for a a single Arduino) inline to prevent race conditions.  This then means that you should only have a single instance of Close.vi per Arduino.
(3,580 Views)
