LabVIEW Interface for Arduino Discussions
Probably something stupid, but I cant compile this firmware
ok, so I've followed every step, even though I was sure I knew what I was doing anyway, and cannot get past this....
I can find plenty of info regarding "unsignerd class" errors, but not a thing about  what you see here. please see attached image.
Any help is appreciated.
Regards
Jason
(4,373 Views)
Have you modified the firmware at all?  The error just says that the code is trying to re-declare that variable.  If no, what version of LIFA and the Arduino IDE are you using?
(3,728 Views)
No, I haven't changed anything yet. Latest IDE and LVIFA
(3,728 Views)
Accepted by jsgarage
Jason,
Your Arduino project looks off.  You have a LVIFA_Base and a LIFA_Base open in the same project.  LVIFA_Base is old, LIFA_Base is current and the two should not be open in the same project.  Also check to make sure you don't have two LabVIEW_Interface files.
At the end of the day you have duplicate files open and hence duplicate definitions of the currentCommand variable.
Hope this helps.
-Sam K
LIFA Developer
(3,728 Views)
Thanks Sammy. That was it. I have no idea now it got in there, either. I re opened the sketch in the arduino IDE, and it wasn't there. Then it compiled. I now have the servo example running. I needed to extend the timeout  in the INIT vi, and then it worked.
Thankyou again.
(3,728 Views)
Happy to help.
-Sam K
LIFA Developer
(3,728 Views)
