LabVIEW Interface for Arduino Discussions
Reading SPI of MAX31855
I have a simple LINX vi pulling data from the MAX31855 via spi I just need
to format it. I'm using pins 13 SCK, 12 SO and 10 CS I'll update everyone
tomarrow.
Message 111 of 131
(8,314 Views)
Hi Nathan,Hi Lex,
thanks for these replies.
@Nathan: this thread was very messy concerning the code that was postted. In the end there where two possible solutions for the LIFA Framework, one was from you (Post 81 of this thread) and one from LexLuther (Post 44 of this thread). Unfortunately, both of the solutions use custom firmware, which I consider unelegant when using LINX because you will loose the platform independence LINX offers.
@Lex: That is good news. I'm eagerly waiting to try your code. I'll hope you share it.
Jan
Message 112 of 131
(8,314 Views)
here is what I put together,the LINX SPI code and the same decoder code Nathan made with lines in correct order.LINX_MAX31855.jpg
Message 113 of 131
(8,314 Views)
Dear Lex,
thank you so much!!! your code worked at first glance. You safed me alot of time by sharing. A big thanks for that again.
In my setup I use 24 MX31855K and my Labview VI now takes approx. 90ms to read out 12 of them. Which is abolutely sufficient for my application. I provide my code and some pictures for future reference.
Probably I´ll post that in the LINX Forum as well if you don´t mind.
all the best,
Jan
Message 114 of 131
(8,313 Views)
That looks awesome! Nathan did the heavy lifting with his code. I just ported it and tested it again.
I've already started a thread on the LiNX forum with the same user name. you should add yours to it,
Message 115 of 131
(8,313 Views)
Hi lex, I have been trying to get the LINX_MAX31855.vi to work but not able to,
I am totally new to labview but have used samples programs in linx to make sure the installation is clean and the boards communicating properly.
However when i run the program LINX_MAX31855.vi it opens up a explorer window asking
me Find the Control named LVH-LINX.lvlib:Interface.ctl.
could you help me out?
Message 116 of 131
(8,313 Views)
I have been able to sort out the earlier issue by manually specifying the path, i think its an issue with changing the name of the direstories from 'labview hacker' to 'makerhub'. However I am getting the errors as above, could you please help me out?
Message 117 of 131
(8,313 Views)
Hi timingalam
I ran into similar problem when try to open "TemperatureSensors-MAIN.vi" I noticed that I file was inside a zip file - perhaps thats the issue.
Solution- Please extract TemperatureSensors_LV2012.zip file into a folder, and then try to open "TemperatureSensors-MAIN.vi". It shows no errors.
Btw, the progm is written in labview 12 version, so you must have Labview12 or newer version. cheers
Message 118 of 131
(8,313 Views)
Can I use this to read Max6675 Thermocouple?
Message 119 of 131
(8,056 Views)
Hey Kkleingasturbine,
I really would like to thank you so much for sharing VI code. Acctually I have some issus, first I'm using Multiple MAX31855 and arduino MEGA2650 when I try to run the code it doesn't show up the MAX31855 values only one connected the digital pins but when I try to connect the second one they stop showing up the results!
I don't why , please if you have any idea it would be apreciated
Thanks in advanced
Sycoder
Message 120 of 131
(7,595 Views)
