Does anyone know how to generate a sine wave on one of the analog outputs using Labview and an Arduino board? I've found some stuff on the web which says you can do it using the PWM output using the arduino compiler/uploader, but I don't know how to translate this code to Labview. I'm new to using arduino and Labview, so any help would be appreicated.
