LabVIEW Interface for Arduino Discussions
Tmp102 Sensor Lifa
It works EXCELLENT!  Thank you very very much!
Message 11 of 13
(1,198 Views)
Thank's a lot and sorry for wasting your time. Thank you very much! God bless you !! Have a great, wonderful life man!!!
Message 12 of 13
(1,198 Views)
"Hello again. I need help, serious help and sorry again for asking again. I have tried again the program, and I get no reading. Already tried on 2 pc's. The problem is that with the arduino IDE works great, I geat temperature readings on my com ( COM 7) , baud rate 9600. I have made constants with this 2 things in the LV on arduino init, and when I run it ( continuously) I get no readings. Nothing happens, and it worked last time. I have reinstalled everything, installed again, from LV, to lifa , uploaded Lifa_Base. If anyone can guide me, or give me suggestions I would really apreciate a lot.
Thank you in advance! Have a nice day!"
Found the solution to the problem. Must install LIFA for 32 bit, even if you use LV  64 bit.
Message 13 of 13
(1,198 Views)
