05-27-2014 12:38 PM
i want to use it on a project ( display of some values in labview , and command outputs from labview )
that's my project,
if you could help me please,
i really need your help,
Thank you
05-27-2014 09:54 PM
When using LINX, you should use the LINX Firmware Wizard to setup the Arduino (do NOT try to upload the source code manually; technically you can but it's not recommend).
P.S. I think you would probably need to downgrade your Arduino IDE to be able to successfully upload LIFA/LINX firmware.
05-28-2014 03:06 AM
why should i always use the LINX Firmware Wizard to setup the Arduino any time i want to test something,
it work once , but on the next try , error msg :
Possible reason(s):
LabVIEW was unable to connect to the LINX device using the following settings:
Interface: Serial
COM Port: COM32
Please make sure that the LINX firmware is loaded on the device (Tools>>LabVIEW Hacker>>LINX>>Firmware Wizard) that there are no other open connections to the device, then check the configuration settings, and try again. ....
and i use firmware again to make it work,
is that how it suposed to be ?
Thank you in advance
05-28-2014 03:34 AM
now i lost ,
should i use lifa or linx, ( linx firmware should re upload at any time want to use it,)
can you help me with this:
i want to use 4 or 5 analog inputs,
and use digital outputs/inputs,
how can i sktech it on labview ,
( im new with labview)
05-28-2014 11:29 AM
You should be using LINX (because LIFA is not actively supported).
I've not used LINX all that extensively but I'm guessing that you might be using the abort button (the little stop sign) to stop your VI. You should use the stop button that you create for you while loop to stop your VI.
05-29-2014 06:34 AM
Hi Nathan,
even if if do,
sometimes stop stuck on runing,
i have this problems only with linx , and not lifa,
what the problem,
i even dump firmware manuely and automatic
05-29-2014 06:49 AM
this is an example of error i get sometimes,
in that error i have just setup firmware of linx from wizard,
vi is read of two analog input ( i use potentiometer )
bottom is from example, ( was working good )
but when i add top one for 2 analog read,
it not working,
maybe vi is not correct ?
let me know THank you
sorry for my english
05-29-2014 11:49 AM
The error is occuring because you cannot initialize the the same Arduino twice. You should only have one Init and one Close. All LINX VIs should be inline with the others (each subsequent VI should use the resource from the previous VI).
05-29-2014 05:38 PM
Hi Nathan,
yes it works, Thank you
05-30-2014 10:30 AM
Hi Nathan,
i want to read digital ,
when i make this vi,
i put a wire in the digial pin,
but it's not stable,
( it go from true to fasle true false )
but when i put the wire on 5v it stop oscillation ( stick on true )
can you please help me ?
maybe there is a problem with the vi or something,
