LabVIEW Interface for Arduino Discussions
Using LIFA pallets in LINX?
Hello, my name is Jesús Galindo,
Can I use LIFA pallets in LINX? It's because I am trying to set some PWM write and I don't know how.
Regards!
(5,684 Views)
Accepted by jesgalindo
No you can not mix LIFA and LINX. They are 2 seperate toolkits and deploy different software to the arduino or device. My suggestion is to use LINX. There is a subvi in the toolkit called /peripherals/PWM/Set Duty Cycle that could be used for this purpose.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,821 Views)
(4,821 Views)
No you can't mix LIFA and LINX as they are 2 different toolkits. I would suggest using LINX as LIFA won't be updated. There is PWM vi in LINX.
(4,821 Views)
And, do you know a place where I can get some tutorials?
(4,821 Views)
Visit the official LINX website (http://www.labviewmakerhub.com/linx).  You can get LINX using VIPM (you don't need to download it because VIPM will download and install it for you).
Once you have it installed, you can go into the example finder and find the LINX examples.
(4,821 Views)
Thank You Nathan,
I really apreciate your time to respond. I'll do it right away.
(4,821 Views)
