01-13-2014 01:00 AM
how i can start the conection betwen arduino and bluetooth hc-06 i find a video on youtube http://www.youtube.com/watch?v=d5fWPqX3uDA the bluetooth in this video is the same
i need conecto this bluetooth because i have a proyect and i dot want controller my arduino whit a cable 😕 please help me
12-02-2015 04:30 PM
Have you find a solution to connect bluetooth module to arduino??
12-02-2015 08:46 PM
What do you mean with "start connection"?
The physical connection?
¿A qué te refieres con "iniciar la conexión"?
¿A la conexión física?
12-03-2015 12:58 AM
i need control servo motors and step motors. RC model
12-03-2015 10:39 AM
If you talk about the physical connection, here you have an schematic...
I do not know if you talked about that.
12-03-2015 12:18 PM
Thanks, me question is how to pair pc with Buetooth module in Labview. I want for example turn on LED over a Bluetooth connection .Maybe you know the steps what i must to do? I found my bluetooth COM4 in VISA, trying to run program, bluetooth module trys to pair, LED stop flashing, but i get error. 5003.
12-03-2015 09:48 PM
Hi dovis.
Maybe I misunderstood your requirement, let me share with you the next link.
In the tutorial you can see how to pair the bluethoot module with your PC.
I hope that instructions can help you.
It would be fine if you show the error message, maybe you could take a screenshot to show the error.
Please, if the answer is correct, choose the "Right answer" button.
Regards
http://www.instructables.com/id/Add-bluetooth-to-your-Arduino-project-ArduinoHC-06/?ALLSTEPS
12-04-2015 09:17 AM
Here you have an example of Arduino + Labview + Bluetooth
12-04-2015 02:16 PM
Thanks, i will try.
12-04-2015 02:33 PM
Verify the baudrate of the Bluetooth, I read something related with that characteristic.
You can use the AT commands to check it in the Bluetooth module.
