LabVIEW Interface for Arduino Discussions
Showing results forĀ
Search instead forĀ
Did you mean:Ā
labview visa query
respected sir
my project is power quality monitoring using  pic micrcontroller as daq, i want to get a sinusoidal signal in visa read output, but i am observing sawtooth wave, plz help me regarding this problemme. tell me what is the problemme, and possible solution for this.
(4,416 Views)
The particular section you are currently in is specific to using Arduino.  You would be better off if you search the NI Discussion Forums.  I know that I've seen a few threads about PIC.
(3,594 Views)
is true, this group is designed to work with arduino, however if someone searches the solution yet how to send data to the arduino is similar in both microcontrollers, labview port interprets values​​, on these links you will find more information
http://www.microchip.com/forums/m440704.aspx
http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Help-me-about-communicating-PIC-microcontro...
http://forums.ni.com/t5/LabVIEW/Program-PIC18F-microcontroller-with-LabView/td-p/1317141
(3,594 Views)
Ramesh1,
You'll have to provide more information for us to be helpful.  Can you describe how the LV and PIC side of your application works?
How fast do you want to sample? How fast is your sine wave?
-Sam K
(3,594 Views)
