LabVIEW MathScript RT Module
Manipulation of dynamic data in Mathscript
I have few questions regarding how to manipulate two dynamic signals in the mathscript. I need to input two dynamic data into the mathscript and take the log inverse of the ratio of two signals.  I tried to get log of these signal but none came as the out put.
In addition, I need to take the very first reading of both signal and use for further manipulation. I used like X(1) but it read several data. If someone can help I appreciate it very much.
amaka
(7,421 Views)
Well, I don't quite see any reason to use mathscript for such a simple task. Why can't you use wires instead? 😄
Message Edited by altenbach on 08-02-2007 07:59 AM
(7,417 Views)
Thank you altenbach,
For the first part it is working. How about storing the very first value for further use. Ex. Value at time zero.  In addition how can I continuously write data into a excel sheet.
(7,405 Views)
