LabVIEW MathScript RT Module
Please Help me!!!
Hallo!!!
Ich need your help!!! Can somebody tell me which result I will get if I start this programm:
Thx
(7,720 Views)
Hello Pate Toni,
guess the result will be 36, right?
After the incrementation and the elementwise squaring one obtains [1 4 9] and the dot product calculates as [1 2 3] * [1 4 9] =36.
Hope this helps.
C.L - NI Germany
(7,709 Views)
In LabVIEW 8.0, the result will be 36.  This is the dot product of [1 2 3] and [1 4 9].  What is the problem you are having?
In LabVIEW 8.2, however, you will receive an error.  In 8.2, all built-in function names must be lower case.  Changing "Dot" to "dot" will let the script run in 8.2.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(7,708 Views)
thx
(7,695 Views)
