LabVIEW MathScript RT Module
Mathscript node problem with specgram function
Hello...
I used to use "specgram" function of matlab, in a M file builded to perform FFT spectral analysis in signals. I am trying to build a VI to perform the same action.
In a blank VI I created a Mathscript node and pasted the code of my M file inside it. After adjust the input and output of the node, I run the VI and received the Error message "Unknown symbol on line 7 : specgram"
How do I solve this issue? How do I execute the specgram inside the mathscript node?
Thank you in advance
Dan07
(6,757 Views)
This is a duplicate post.  Continue the discussion here: http://forums.ni.com/ni/board/message?board.id=170&message.id=327967
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(6,726 Views)
