LabVIEW MathScript RT Module
imagedata
hi,
      i used a picture function to read JPEG file and now want to send the image data to a mathscript input but iam not able to find an input datatype that can support this imagedata.pls help...
(6,871 Views)
On the same palette as the image reading VIs (Programming >> Graphics & Sound >> Graphics Formats), there is an "Unflatten Pixmap VI."  This will return a 2D array of image data that you can wire to the MathScript node.  In LabVIEW 8.5, MathScript has an imread command.  This function will read an image file from within MathScript.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(6,856 Views)
