LabVIEW MathScript RT Module
Peirce's method
I want to implement Peirce method for outlier rejection and run it with Mathscript.
Everything is running perfectly fine in MatLab but in Labview i become error message "  Line 29, Column 6: unexpected char: '.'  "
This seem to be simple error but I am a novice. I kindly ask you to help me to solve this problem.
See attached file for the code.
Best regards
Alan
(6,895 Views)
Accepted by Alanko
Mathscript nodes do not support structures.  Your error occurs because of the part of the code where you populate the info struct.
Randall Pursley
(6,890 Views)
