LabVIEW MathScript RT Module
Very urgent
Hi iam R.Prem kumar . I have done wavelet signal and image compression in matlab 7.0.1. I tried to run that code in in labview using math script node . It is not working . please help me . its very urgent. i have only Labview 7.1 and advanced signal processing tool kit 7.0.1. The code is working fine in Matlab.
R.Prem kumar
+919940446193
(7,186 Views)
Hello!
MathScript Node was introduced in LabVIEW 8.0 i.e. was not present in LabVIEW 7.x. I guess you are using either the Formula Node that won’t let you run M-files or make use of the Matlab Script Node that allows you to call M-files from LabVIEW but they are actually executed within the Matlab environment.
It might also be so that the Matlab Script Node is not compatible with the version of Matlab you are using. Some things were fixed in the LabVIEW 7.1.1 release.
See this link:
http://digital.ni.com/public.nsf/websearch/4475BC3CEB062C9586256D750058F14B?OpenDocument
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(7,155 Views)
