04-10-2007 02:37 AM
05-07-2007
04:58 AM
- last edited on
08-06-2026
10:59 AM
by
Content Cleaner
Hello!
MathScript Node was introduced in LabVIEW 8.0 i.e. was not present in LabVIEW 7.x. I guess you are using either the Formula Node that won’t let you run M-files or make use of the Matlab Script Node that allows you to call M-files from LabVIEW but they are actually executed within the Matlab environment.
It might also be so that the Matlab Script Node is not compatible with the version of Matlab you are using. Some things were fixed in the LabVIEW 7.1.1 release.
See this link:
http://digital.ni.com/public.nsf/websearch/4475BC3CEB062C9586256D750058F14B?OpenDocument
