LabVIEW MathScript RT Module
can't edit mathscript node
Created a VI that uses a MathScript Node. Need to change code in said MathScript Node. I cannot do this because I am not allowed to edit the MathScript Node. Why is this a feature of the MathScript Node? Am I missing some understanding of the functionality of the MathScript Node? I cannot even add or delete inputs or outputs to the Node. Write clicking does nothing. Double left clicking only highlighs the entire Node to be moved around the Block Diagram. That is the only thing I am allowed to do to the MathScript Node; move it around the Block Diagram.
(8,795 Views)
Most likely you don't have Mathscript installed on the system you are currently using. Where did you create the VI?
If you think the problem is something else, please attach the VI so we can have a look.
(to be take more seriously, I recommend you change your user name).
(8,791 Views)
Reported to moderator
(8,777 Views)
So what is there to be reported to the moderator?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(8,297 Views)
My guess is that there was a spam posts that got removed by the moderator. The above comment should have been removed with it to avoid confusion. 😉
(8,290 Views)
