LabVIEW MathScript RT Module
Empty 1D array
Hi
I want to declare an empty 1D array in MathScriptRT node.
This code give a 2D array.
a = [];
I know in Matlab the above code will give me an empty 1D array.
Could anyone tell me how to declare it?
I am using LabVIEW 2013sp1.
(8,927 Views)
I found a solution
a = zeros(1, 0);
But I am not happy with it. I need a simpler way.
(8,923 Views)
Accepted by topic author fucai1116
A simpler way would be not to use mathscript at all and simply use an empty 1D array diagram constant. 😄
(8,921 Views)
It does not like what NI advertised that most of basic MATLAB code can run on MathScript.
(8,882 Views)
What is "it"?
Maybe you are mistaken in your assumption? Looking at the matlab help,
a = [];
will create a 0x0 array, which is by definition 2D, right? A matrix of zero columns and zero rows!
(8,878 Views)
HI altenbach
I was mistaken. I did not check carefully. a = [] will create 0x0 matrix.
Thank you
(8,823 Views)
