LabVIEW MathScript RT Module
"if" dosnt work in mathscript node
Hello
I have a strange problem in mathscript node, can u help me?
I just write a simple conditional style in mathscript node, but it dosent work and have attached error! my software has problem?
Best Regarsd
behzad
(8,215 Views)
Accepted by topic author behzad1
The problem is that your output "out" is undefined, as executed in your script. This might be what you want instead
out = -1; % define default value for out
if in == 7
  out = 6;
end
Kevin C.
(8,203 Views)
Hi
I really appreciate Kevin for his great help.  that was very Helpful to me.
can u help me about new problem in output too? when I set output  to zero or one, how can I convert to a boolean number? because  output with 0 or 1 , cant connect to a boolean LED.
Best Regards
behzad
(8,183 Views)
use a !=0 before wiring to the led.
(Nothing of what you are doing requires the complications of the mathscript node. Why don't you just use plain LabVIEW instead?)
(8,180 Views)
Thank u altenbach.
actually I have a Complex Matlab code, that I just try to seperate code to small parts to Understand that and Easily transform to labview code. Integrated form is some difficult to debug.
Best Regards
(8,175 Views)
