LabVIEW MathScript RT Module
capture data using mouse
hi,
that's amazed. how did u do that? property node to add the cursor? btw how come the x-axis is not showing any data?
Message 11 of 16
(5,557 Views)
To display the cursor, enable the Cursor Legend in Visible Items in the short-cut menu of Graph control. Then, create a singel plot cursor in the Cursor Legend.
In your VI, the x-axis is time data. Therefore, it always display 08:00:00 01/01/1904. When you use XY Graph, the X should display the x-coordinate of the cursor position.
Message 12 of 16
(5,551 Views)
when i use the xy graph, it always display 08:00:00 01/01/1904 even though i move the cursor. could it be because i did not set the parameter correctly?
Message 13 of 16
(5,545 Views)
Yes, the x value of cursor depends on the x-coordinate of the plotted data.
It always displays 08:00:00 01/01/1904 because dt is set to 0.01 second in your code.
Message 14 of 16
(5,542 Views)
wow that's a tough one. so if i am suppose to get at 0.2 sec, it will not be possible to get from the xy graph?
Message 15 of 16
(5,535 Views)
I think it is better to use XY Graph instead of Waveform Graph for your application.
See the attached VI for reference.
Message 16 of 16
(5,529 Views)
