LabVIEW MathScript RT Module
plotting of graph
hi,
let say i got this equation.
Kc=1;
Ti=1;
Td=1;
L=1;
w=0.01:0.01:1.01;
PID = Kc*(1+ 1./(j*w*Ti) + j*w*Td/((j*w*Td/10)+ 1));
block1 = angle(exp(-j*w*L).*(j*w+1).^(-6) .* PID) + pi;
plot(w,block1);
how do i plot in labview as i got no problem in matlab?
Thanks in advance.
(7,771 Views)
nonmm,
You can open LabVIEW, go to Tools>>MathScript Window..., then click the Script tab and enter your script there. Alternatively, you may try something like the attached VI.
Hope that helps,
KevinC
(7,762 Views)
oh thanks 🙂 how about the command of "ginput" (using of mouse) can it be used in labview?
because once i got the graph, i need to get the point that touches the zero crossing line by using mouse in order to do another calucation.
(7,758 Views)
MathScript supports the command of ginput.
Below are the syntax and description of ginput.
[x, y] = ginput
[x, y] = ginput(n)
[x, y, b] = ginput
[x, y, b] = ginput(n)
Acquires data points from the current plot by a mouse click. [x, y] = ginput acquires data points until you press the <Enter> key. [x, y] = ginput(n) acquires data points until LabVIEW acquires n data points or until you press the <Enter> key.
In LabVIEW, you can use the cursor of XY Graph.
(7,748 Views)
