LabVIEW MathScript RT Module
error 90026
hi every body,
i desperately need a help with mathcrip. i'm trying to run the vi on the attached when i got this error error 90026.
could someone help me how to fix it pliase?
labview 8.5
(7,296 Views)
Hi tchaou,
The message I see for error -90026 is, "Error in function '=' at line 13.  The indexes for a matrix indexing operation must be real, positive integers." At line 13 it looks like you are using D as an index. Indices in MathScript are 1-based, which means the value you input for D must be at least 1. Since you also use t as an index (on line 15), it must also be 1 or greater. If I set the "Distance de la source X" and "Temps instantané" controls to be 1 then I can run the script without error.
Here's a tip when you're seeing problems like this with intermediate values in your MathScript Node. In LabVIEW 8.5 you can right-click the node and select "Probe". Then when you run your script you will see a list of all the variables that get created. You can click on them and inspect their values. That's how I first figured out that D and t were not valid indices.
Hope this helps.
jattas
LabVIEW Math & Signal Processing
(7,293 Views)
