LabVIEW MathScript RT Module
mathscript syntax question
Can any tell me why this does not compile.  I get a red X on the last line, and the variable LampV is shown in red, and is an output.
I seem to have a problem using multiple conditional statements in one script.
Deleting the last conditional statement removes the error.  The error refers to the last line and says "Line 14, column 1: expecting EOF, found 'end'
if (RadLampV > IrrLampV)
Bench = 'Radiance' ;
CradleT = RadCradT;
LampV = IrrLampV;
LampT = IrrLampT;
else
LampV= RadLampV;
CradleT = RadCradT;
LampT = IrrLampT;
Bench = 'O_Irradiance';
end;
If LampV < 0.1
Bench = 'unknown';
end;
(7,543 Views)
Accepted by topic author rockybooth
I think your error may be that your second if statement is capitalized. Try replacing "If" with "if".
Kevin C.
(7,530 Views)
ThanksThat solved it!
(7,518 Views)
