LabVIEW Public Beta Program in 2024
Beta Change: TLS Updated to OpenSSL 3.0
Warning: Installing the LabVIEW 2024 Q3 Beta will replace LabVIEW 2024 Q1 if installed. Also, you will need to uninstall LabVIEW 2024 Q3 Beta before installing the release version; upgrading with NI Package Manager will not work.
LabVIEW TLS support has been recompiled to use OpenSSL 3.0. We would appreciate regression testing with client use cases.
Caveats and Known Issues
  1. Certificate and key loading from disk doesn't work.
  2. Server usage (Accept TLS) does work (but may not be usable because of the above).
  3. TLS 1.3 is not yet tested and not yet expected to work.
  4. HTTP Client, SMTP Client, and WebDAV client have not yet been updated.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(1,497 Views)
I am using LV 2023 Q3. I never installed LV 2024. Regardless, I need to get this issue resolved.
ETA: Posted reply in wrong thread.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(1,468 Views)
Did "LabVIEW TLS support has been recompiled to use OpenSSL 3.0." make it into LabVIEW 2024 Q3 release?
Shane.
(1,039 Views)
Shane.
Yes.
Christina Rogers
(1,024 Views)
