LabVIEW Public Beta Program in 2024
Completely messed up Y axis when U32 is formatted in hex
I run across this in 2020 and was annoyed, so I tested in 2024Q3 and the problem is still there. Just wondering if this is a known bug and where I should report it, if not. Is mentioning it here sufficient?
Basically, I have a graph for an U32 array and want to see all date scaled to the allowable range:
Autoscale off, Ymin=0, Ymax=FFFFFFFF
Bam! If I try to enter FFFFFFFF, It changes to FFFFFFFFFFFFFFFF 😮
... and yes, the same happens if I do that on the X axis!
Note that if I graph U32 data that is all xFFFFFFFF, I cannot see the data at all unless I go back to autoscale. Then it shows as follows:
(601 Views)
This issue has been reported to LabVIEW R&D as Bug 2843028.
(546 Views)
