LabVIEW Public Beta Program in 2025
Internal Warning when opening previous version project
This is on a Windows 10 22H2 VM.  I copied one of the projects I am working on (in LabVIEW 2021 SP1) over and tried opening in the 2025 Q3 beta.  The project eventually opens successfully when I click OK on the warning.  The warning occurs every time when opening the project as-is, but it happens far less frequently once I save all in the Beta and the project.
(721 Views)
Moving the now-saved-in-the-beta project into a directory that guarantees long paths yields another (different) internal warning:
Once again, the project opens successfully after you click OK on all the internal warnings.
Note that I have a different project originally saved in LabVIEW 2019 that does not generate either of these internal warnings.
(703 Views)
Thank you for testing! I've filed Bug 3139631 for this.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(658 Views)
