LabVIEW Public Beta Program in 2024
Path is absolute to .NET dll in LV2024 Q1 from a .lvlibp contaning a LVClass.
Hello Beta Team,
I found a bug when building a lvlibp with LV2024 Q1 I got link to my .NET dll as absolute Path, instead of relative path from the PPL.
I have attached a project with a .lvlib containing a lvclass containing a vi that call a .NET dll.
This example is saved in LV2021 and work correctly since LV2013 ... But now in LV2024 Q1 it fail due to the PPL search for the dll at the original absolute Path that the DLL was placed.
Just let me know if you need more information.
Dany
LabVIEW ChampionArchitect
Message 1 of 10
(2,871 Views)
I filed Bug 2645388 for this, but, for future reference, you can report issues that aren't related to the Beta (i.e., the preview features) using the normal channels instead of this forum.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 2 of 10
(2,812 Views)
Thank you Christina, I will use the normal channel the next time sorry.
Dany
Message 3 of 10
(2,808 Views)
By chance, do we know if this was fixed in the patch that was released a few days ago?
This bug is preventing me from using LV 2024 too heavily at the moment.
(I know this probably not be on the beta board, but since this thread is already open, I hesitate to open a new one somewhere else, and I'm not aware of a place to check for bug statuses in general).
EDIT : Nevermind, I see that patch was JUST for the community edition!
Message 4 of 10
(2,591 Views)
No, the patch was for LabVIEW.  There are a couple of bugs directly related to the Community Edition, but the patch, overall, is for LabVIEW itself.
Message 5 of 10
(2,581 Views)
This bug sounds similar to an issue I had with LabVIEW 2016.  It was filed under CAR 683350 (I only have the old bug database number).  In my case, the work around was to change the .NET references in my class inside the PPL to reference a class in the GAC.  So I had to add some To More Specific Class calls in my code to get the behavior I wanted.
Message 6 of 10
(2,580 Views)
The NI Download page has the patch ONLY downloadable for 32-bit Community Edition.  However, Once I went into NIPM, the update was there.  I'm not sure if the website thing is a "me" thing or an "NI" thing.
Message 7 of 10
(2,572 Views)
That's good to know that there (might) be a workaround for this... However I'm not sure that that's a realistic workaround right now... That being said, I haven't "seen" this bug myself.  I saw this report, and the logged bug, and opted to spend my time working on other things, but there's at least one application I like to keep compiled in the latest "reasonable" version of LabVIEW, and it's PPL/Plugin based which has .NET dependencies... so this would be a blocker.
Message 8 of 10
(2,570 Views)
I see what you are seeing as well.  I downloaded it before that page came up.  If you change the version to 2024 Q1 and set the Driver Software Included to No, you will see the patch as an available offline download.
Message 9 of 10
(2,567 Views)
I apologize, we're having some problems with the download page. The patch is not just for Community Edition. We're working on getting the page fixed.
Unfortunately, though, this bug hasn't been addressed with this patch. LabVIEW R&D is still researching the issue.
Christina Rogers
Message 10 of 10
(2,539 Views)
