LabVIEW Real-Time Idea Exchange
TiTou
Make Redis available via opkg
Status: New
Redis is a very useful tool, I've been trying to compile onr from the source code but haven't succeeded so far.. I'm sure doable.
Being able to host a small in-memory database on a cRIO would be so much better and easy and faster and more flexible than using shared variable or TCP communication.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
1 Comment
JensG69
Active Participant
Redis is available on Linux cRIOs.
Login into your cRIO via SSH and run these command:
opkg update
opkg install redis
change the config, if necessary, e.g. by
vi /etc/redis/redis.conf
reboot
Jens
Kudos are welcome...
