LabVIEW Shortcut Menu Plug-Ins
InsertVI.llb
Author: Chris Virgona
When I need to insert an item, I've always hated the workflow: "Right-click >> Insert >> All Palettes >> Select a VI..."
Why can't we just do "Right-click >> Insert VI..."? Well, now we can!
This plugin adds an "Insert VI..." menu at the top level of the palettes:
The insert function also supports multi-wire select, so you can select multiple wires and insert your VI with all wires connected. (Credit: Multi-select code copied from QD:Insert.vi - thanks Darren!)
Attachments saved in LabVIEW 2020 (.llb) and LabVIEW 2023 (.zip). For install instructions, go here.
Comments
fabric
Active Participant
Active Participant
on
This plugin does Insert. I also provided a similar Replace plugin here.
Contributors
