LabVIEW Team Indonesia
PROBLEM DEPLOY PROGRAM DETEKSI WARNA KE RASPBERRY PI 3 B
Izin bertanya master,nama saya abdullah syukron,problem saya yaitu ada error saat saya deploy program pendeteksi warna ke raspi problemnya saya lampirkan di bawah ini :
1. program Pendeteksi warna
2. Problem Deploy ke Raspi
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying NI_Vision_Development_Module.lvlib
Deploying LMH-LINX.lvlib
Deploying LMH-LINX.lvlib:Device.lvlib
Deploying NI_Vision_Acquisition_Software.lvlib
Deploying LMH-LINX.lvlib:Local IO.lvlib
Deploying LMH-LINX.lvlib:myRIO.lvlib
Deploying LMH-LINX.lvlib:DS1307.lvlib
Deploying LMH-LINX.lvlib:PmodTMP3.lvlib
Deploying LMH-LINX.lvlib:PmodACL.lvlib
Deploying LMH-LINX.lvlib:PmodMAXSONAR.lvlib
Deploying LMH-LINX.lvlib:PmodGPS.lvlib
Deploying LMH-LINX.lvlib:PmodCMPS.lvlib
Deploying LMH-LINX.lvlib:PmodALS.lvlib
Deploying LMH-LINX.lvlib:PmodACL2.lvlib
Deploying LMH-LINX.lvlib:PmodBT2.lvlib
Deploying LMH-LINX.lvlib:PmodTC1.lvlib
Deploying LMH-LINX.lvlib:PmodGYRO.lvlib
Deploying LMH-LINX.lvlib:PmodJSTK.lvlib
Deploying LMH-LINX.lvlib:PmodMIC3.lvlib
Deploying LMH-LINX.lvlib:SSD1306.lvlib
Deploying LMH-LINX.lvlib:Ultrasonic.lvlib
Deploying LMH-LINX.lvlib:TMP3x.lvlib
Deploying LMH-LINX.lvlib:TCN75A.lvlib
Deploying LMH-LINX.lvlib:Interaction Parts Kit.lvlib
Deploying LMH-LINX.lvlib:Servo.lvlib
Deploying LMH-LINX.lvlib:LTC2631.lvlib
Deploying LMH-LINX.lvlib:AD9850.lvlib
Deploying LMH-LINX.lvlib:WS2812.lvlib
Deploying LMH-LINX.lvlib:BlinkM.lvlib
Deploying LMH-LINX.lvlib:HiTechnic.lvlib
Deploying LMH-LINX.lvlib:HiTechnic.lvlib:Accelerometer.lvlib
Deploying LMH-LINX.lvlib:ADXL345.lvlib
Deploying LMH-LINX.lvlib:MPU60X0.lvlib
Deploying LMH-LINX.lvlib:MMA8452.lvlib
Deploying LMH-LINX.lvlib:MMA8451.lvlib
Deploying Raspberry Pi 2 B(successfully deployed target settings)
Deploying Image Type (1.31 K)
Deploying Error Code Database.vi (4.39 K)
Deploying LMH-LINX.lvlib:Device.lvlib:Packet Number FGV Action.ctl (1.32 K)
Deploying whitespace.ctl (1.32 K)
Deploying NI_Vision_Acquisition_Software.lvlib:IMAQdx Buffer Number Mode.ctl (1.31 K)
Deploying LMH-LINX.lvlib:All Firmware Data FGV States.ctl (1.32 K)
Deploying Search and Replace Pattern.vi (8.38 K)
Deploying LMH-LINX.lvlib:Device.lvlib:Bit Pack.vi (5.18 K)
Deploying TagReturnType.ctl (1.32 K)
Deploying DialogTypeEnum.ctl (1.32 K)
Deploying LMH-LINX.lvlib:User Platform.ctl (1.32 K)
Deploying LMH-LINX.lvlib:Channels.ctl (4.50 K)
Deploying IMAQ Image.ctl (1.35 K)
Deploying LMH-LINX.lvlib:Interface.ctl (1.32 K)
Deploying LMH-LINX.lvlib:Device.lvlib:Firmware Version.ctl (1.43 K)
Deploying DialogType.ctl (1.32 K)
Deploying Error Cluster From Error Code.vi (9.29 K)
Deploying LMH-LINX.lvlib:Device Firmware.ctl (2.51 K)
Deploying GetRTHostConnectedProp.vi (3.83 K)
Deploying LMH-LINX.lvlib:Device.lvlib:LINX VI API Version.vi (2.93 K)
Deploying IMAQdx.ctl (1.35 K)
Deploying NI_Vision_Acquisition_Software.lvlib:IMAQdx Get Image.viNI_Vision_Acquisition_Software.lvlib:IMAQdx Get Image.vi loaded with errors on the target and was closed.
Deployment completed with errors
Mohon pencerahanya dari para master.Hatur Nuhun
(2,923 Views)
Dear Mas Abd_Syukron,
Boleh tahu mas apakah mas mencoba tutorial atau bagaimana? Jika tutorial, mungkin boleh share link nya?
Jika dilihat dari proses deploy nya memang terkendala di deploy fungsi Visionnya ya, jika saya cek library dari Vision Acquisition Software ini, bisa dipastikan bahwa ndak kompatibel karena limitasi dari LINX itu sendiri
Pertanyaan yang sama saya temukan di beberapa forum NI yang ada diluar, seperti:
  1. Trouble with Labview version creating a Stand-Alone application for Raspberry
  2. Capture Image on Raspberry Using LINX Labview Application
Alternatif yang bisa kita lakukan ada dua, yakni:
  1. Jika tetap ingin menggunakan Raspi 3, kita bisa menggunakan OpenCV
  2. Menggunakan RIO hardware, jika mahasiswa bisa menggunakan myRIO
Happy Programming!
F
(Menjawab pertanyaan? Marked as Solution! Biasakan beri kudos yuk untuk tahu apakah solusi kita bermanfaat 🙂 )
(2,890 Views)
iya pak liat tutorial dan di kasih linx sendiri  agar bisa di deploy ke rapi ternyata VAS tidak supot ke Raspi.
1. saya ingin membuat program pendeteksi warna menggunakan VAS berarti tidak bisa pake raspi ya pak..?
2. kalau pake open CV apakah VAS masih bisa digunakan dalam pembuatan programnya atau labview hanya menampilkan program yang di buat di OpenCV pake C++ atau Pyton..?
3. ini link tutorialnya  https://www.youtube.com/watch?v=gcwG44SdxP0&t=181s
selain pake MYRIO dan OPENCV tidak ada cara lain yang bisa deploy program labview VAS ke Raspi misalnya pake arduino. saya menggunakan webcam Logitec C170.
Terimakasih
(2,881 Views)
Dear mas Abd_Syukron,
NI Vision (termasuk VAS) ini sendiri merupakan software untuk developing aplikasi profesional, untuk mendeploy dengan menggunakan LINX (dimana umumnya Raspi, BeagleBone dan Arduino umumnya ditujukkan untuk hobbyist) ini yang akan memberikan limit pada deployment mas nantinya.
In short, ndak bisa pakai VAS untuk ke dalam Raspi
Mengenai alternatif dengan OpenCV mungkin yang paling dekat, namun sejauh yang saya tahu masih belum ada VI library jadi yang tinggal pakai bahkan untuk Windows jadi nantinya kita butuh pemrograman C++ yang dalam CMIIW
Atau bisa juga membuat proses image acquisition dan analysis ke dalam Python module dan dipanggil sebagai external command melalui command line dari System Exec.
Intinya akan cukup menantang kalau mas tetap ingin menggunakan ini. Referensi yang saya lampirkan sebelumnya cukup bagus mas jika mas tertarik lebih jauh kenapa demikian.
Happy Programming!
F
(2,870 Views)
