LabVIEW Web UI Builder and Data Dashboard
Error handling in the LVWebUIBuilder
Impressive stuff.
I don't see any error handling mechanisms in the LVWUIB.  Are they there, and I'm missing it?
Joe Z.
(8,044 Views)
Accepted by topic author Underflow
Hi Joe,
With the error cluster, you can use the Unbundle Error function (http://zone.ni.com/reference/en-XX/help/373286A-01/uibuilderref/wuib_unbundle_error/).
To add error handling to your subVIs, you need to create error terminals from any function that has error inputs and outputs.  Then, select the View tab and click SubVI Settings.  From there you can add error in and error out terminals.
You can create error windows using the Display Debug Assert function (http://zone.ni.com/reference/en-XX/help/373286A-01/uibuilderref/wuib_display_debug/😞
Note that I have to invert the error boolean to make the dialog pop-up.
(8,037 Views)
Thanks Kyle, that makes sense.
JZ
(8,027 Views)
