LabVIEW Web UI Builder and Data Dashboard
labview + ios iphone
hey, what's up . i'm trying to connect my ios device with a shared variable but it gives me a error. "cannot connect to the server" please help me. i tried my a local adhoc network, i added a static ip's  + such as , CIP 192.168.1.1 , subnet mask 255.255.255.0 and gateway 192.168.1.2(my ios device) but the same error apeared so, i also tried with the hotspot network of my cellphone but it was more easy because the ip's were designed by DHCP. maybe i'm doing wrong in any step of labview, anyone can help me?
(8,101 Views)
hahaha, finally i got it, the problem was the windows firewall. 😄
(8,096 Views)
Great!
Remember that you have to be connected to the same network to use Data Dashboard..
(8,068 Views)
You only need to be able to access the server and the right ports. You do not have to be on the same network (unless you count "The Internet" as one single network).
(8,064 Views)
