LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
How to control the Steering gear by nxt?
I am using the LabVIEW NXTTOOLKIT to control a Steering gear.THe steering geering is controlled by PWM,period 20MS,Pulse-width 0.5MS.
My  question is easy:
How to generate this PWM by LabVIEW NXTTOOLKIT?
ADD a question:
I want to use PID for the motor,but the nxt donot support float,how can I do?
king
(8,040 Views)
So you have a motor that is controlled by a PWM? How have you connected this PWM to the NXT?
You could suply power to the PWM by programming it with a NXT motor VI. Have the VI "run" the "motor" for whatever the amount of time one pulse is for your PWM. Then just repeat that action in a while loop.
(8,025 Views)
THE vi changes pulse width,the  frequency is 8K Hz,I want to change the frequency to 50Hz,which parameter in NXT_MotorUnlimited.vi change the parameter?
king
(8,023 Views)
THE vi can change output pulse width,the  frequency is 8K Hz,I want to change the frequency to 50Hz,which parameter in NXT_MotorUnlimited.vi changes the frequency?
king
(8,022 Views)
For your float problem, if you needed 2/3, you could devide 2 by 3 and you would get your answer. Of course, if you do that directly and ask for an asnwer, it will be rounded, but depending on what you are trying to ultimately do, it might work.
(7,918 Views)
Since the NXT doesn't support floating point, you'll need to re-implement the PID algorithm using integers. A google search would give you the following resources:
http://www.google.com/search?q=integer+pid+implementation
http://www.acroname.com/examples/10059/10059.html
http://www.advice1.com/reference/pidalgorithmref.html
Joel Sumner
NI-Shanghai
(7,910 Views)
