LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
PWM Output on NXT
Hey All,
I am currently involved in a student project involving the NXT, and using Labview to produce the code.
Is there a way to output a Pulse Width Modulated signal from the output ports on the NXT, using Labview and the NXT toolkit.
Any help will be appreciated.
Thanks!
(7,060 Views)
@Whitey86 wrote:
Hey All,
Thanks!
Here's another discussion that talks about it.  The NXT motors are controlled via PWM signals so you can use the motor blocks to generate certain PWM signals.
http://forums.ni.com/ni/board/message?board.id=beta18&message.id=697
Joel Sumner
NI-Shanghai
(7,047 Views)
