LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Kalman Estimator Structure
I want to control the two wheel nxt inverted pendulum robot using state-space controller in Labview.
The state-space model of the robot has
6 states (YawAngle, YawAngluarVel, PitchAngle, PitchAngluarVel, WheelAngle, WheelAngluarVel),
2 inputs (LeftMotrorVoltage, RightMotroVoltage),
3 outputs (WheelAngle, PitchAngluarVel, YawAngle).
I have calculated the full state feedback gains which is a 2x6 matrix.
Since I have 2 control inputs, 3 measured outputs (3 out of 6 states), I need to create an estimator(Kalman).
Could any one can explain me the followings:
1-What would be the size of the kalman G,Q,R matrix?
2-When can I use the elements of G matrix as unity?
(6,733 Views)
I can give you some links which maybe help you to realize your project:
Kalman Estimator: http://documents.wolfram.com/applications/control/OptimalControlSystemsDesign/10.7.html
How can I learn to program the NXT?: http://www.nxtprograms.com/help/learn.html
NXT Segway with Rider: http://www.nxtprograms.com/NXT2/segway/index.html
I hope this helps.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(6,687 Views)
