LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Labview 2009 i2c "error file!"
Hi everyone,
i am using Labview 2009 with the nxt module and firmware 1.28
when i try to debug the example of the i2c to read and write (from PIC microcontroller)
i get the message  "error file!" on my NXT lcd.
what is the problem and how can i fix it?
good day.
Message 1 of 9
(8,110 Views)
any idea?
Message 2 of 9
(8,102 Views)
Which specific example are you running?  Are you able to run other code?  Can you narrow down the cause of the error to a specific VI inside of this example?
Hopefully with a little more information we will be able to figure out exactly what is happening.
Justin Parker
Product Support Engineer
Message 3 of 9
(8,096 Views)
thanks for the replay.
i am trying to run the example "setupi2c.vi" from the examples of the NXT module i downloaded
i attached the vi to this message.
 when i try run or debug i get "file error!" message on the NXT lcd.
 i am only tring to send multibyte from PIC to the NXT by using labview code and it doesnt seems to work
does anyone knows:
1.why i get "file error!" message?
2.besides that example is there any other way to send recieve multibytes on the NXT?
thanks again.
itai
Message 4 of 9
(8,079 Views)
I am having exactly the same problem. It would be great if anybody could help us on that.
Message 5 of 9
(7,133 Views)
I am not able to open the attached file in LabVIEW. I found the example PI_Position_Control.vit for the NXT and does this VI help? Have you tried to run this one or does this not apply to what you are trying to accomplish?
Message 6 of 9
(7,118 Views)
I can run the other functions in the nxt module. It works perfectly. But, I could not use i2c function. I download the file to NXT but I cannot run it. Immediately after I run the program program stops generating "file error" in the display. I am using Labview 2009 with NXT module for the version and firmware on my NXT is 1.28. I have attached the file that is based on the example given on:
http://zone.ni.com/reference/en-XX/help/372962A-01/lvnxt/i2c_sensors/
Message 7 of 9
(7,114 Views)
Hi Binay,
"File Error!" happens for a number of reasons and is a fairly non-descriptive error string. It can mean: Your file is corrupt, there was a run time error during program execution, or you run out RAM during program execution.
I ran the code you attached in LabVIEW 2010 SP1 on a NXT controller with firmware 1.28, and I couldn't reproduce the error. However, I didn't have a sensor attached either..
Can you reproduce the issue with a new VI? Can you verify that you can communicate with your microcontroller with another device via I2C? Can you try running your code on another machine, perhaps one with a later version?
I don't see why it may be related, but can you upgrade to the latest NXT firmware: 1.29?
Fred Visser -- SystemLink R&D -- National Instruments
Message 8 of 9
(7,096 Views)
After I read your post I tried the program using labview 2010 and it worked. Thanks for your help.
Message 9 of 9
(6,992 Views)
