LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
I2C problem between the NXT and a Maxim DAC
Hi everyone.
I'm using LabView 2009 service pack 1 an a NXT firmware 1.28 .
My goal is to command an DAC "MAX 127" from Maxim through a NXT. The DAC is connected to the NXT by the sensor plug.
Here the doc :
MAX 127 documentation
I got some problems. I can not discuss with the DAC, with the NXT module "i2c communication".
I don't see any digital signal on the oscilloscope.
Could you help me to fix it.
Sincerly
Remi Cambuzat
(6,319 Views)
Hey Remi,
According to the Max127 DAC, to make sure the device is I²C compatible, you have to wire the SDA and SCL inputs to pull-up resistors. Did you do that ?
You should find some useful examples shipped with the NXT module (in LV : Help -> Find Examples -> Toolkits & Modules -> NXT).
As a last resort, you may need to upgrade to LV2010 because we have been experiencing some issue with I²C between LV 2009 and NXT 1.28.
Regards
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(6,299 Views)
Thanks for the answer.
I got some pull-up resistor on SDA & SCL.
Here is the scheme :
I've instaled the NXT modules on Labview 2009 and it seems possible to use the I2C protocoles.
Do you think the easiest way is to upgrade to LV 2010 ?
Sincerly
(6,294 Views)
