 Kosen
			Kosen
			03-21-2011 10:28 AM
Hi everyone.
I'm using LabView 2009 service pack 1 an a NXT firmware 1.28 .
My goal is to command an DAC "MAX 127" from Maxim through a NXT. The DAC is connected to the NXT by the sensor plug.
Here the doc :
I got some problems. I can not discuss with the DAC, with the NXT module "i2c communication".
I don't see any digital signal on the oscilloscope.
Could you help me to fix it.
Sincerly
Remi Cambuzat
 Eric.M
			Eric.M
			03-22-2011 06:00 AM
Hey Remi,
According to the Max127 DAC, to make sure the device is I²C compatible, you have to wire the SDA and SCL inputs to pull-up resistors. Did you do that ?
You should find some useful examples shipped with the NXT module (in LV : Help -> Find Examples -> Toolkits & Modules -> NXT).
As a last resort, you may need to upgrade to LV2010 because we have been experiencing some issue with I²C between LV 2009 and NXT 1.28.
Regards
Eric M. -  Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer -  Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
03-22-2011 10:32 AM - edited 03-22-2011 10:38 AM
Thanks for the answer.
I got some pull-up resistor on SDA & SCL.
Here is the scheme :
I've instaled the NXT modules on Labview 2009 and it seems possible to use the I2C protocoles.
Do you think the easiest way is to upgrade to LV 2010 ?
Sincerly
