11-13-2009 09:07 PM
hi I would like to ask if it is possible to send a SMS message using our Lego NXT Mindstorm 2.0.
What language/s are we going to use?
So far we are starting to connect the NXT brick to a PC but unfortunately, it cant connect because the NXT bricks says that the line is busy..
How was that? can u please respond to my question?
Thanks in advance!
11-16-2009 05:23 PM
Unfortunately, the NXT will not be able to send an SMS directly, but there are ways we can work around this. What we can do is the following:
1. We'll need to create a VI on the Windows PC to receive messages from the NXT. The NXT Mail VI will help you send data from the NXT to the Host.
2. Take a look at this example for sending an Email via .NET:
http://decibel.ni.com/content/docs/DOC-7451
You can use this example to send a message to an SMS gateway, which sends it to your phone.  Another SMS example using the LabVIEW Internet Toolkit can be found here:
http://decibel.ni.com/content/docs/DOC-4374
As far as your other issue, are you using USB or bluetooth? Are you using a USB hub? If so, if you directly connect the NXT to the computer, does it work?
11-21-2009 11:44 PM
11-23-2009 01:29 PM
Hi Weeward,
As long as you post in the NXT forum, we'll be sure to answer it. Thanks!
