LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Measure distance using Color Sensor 2.0
Hello everyone!
I'd like to know if there's any way to measure the distance to an object using the color sensor that comes with the Mindstorms 2.0. I acquire some lectures from the sensor but I don't know how to convert this values to distance.
Any reference or link would be appreciated!
Thanks!
Francisco José Gómez López
Software Engineer
(8,615 Views)
Accepted by fran_jo
Hi fran_jo,
Here's an article that offers a good method for calculating the correct scaling values to convert the intensity measurements to distance:  http://www.hitechnic.com/blog/eopd-sensor/eopd-how-to-measure-distance/.  Keep in mind that this relates to a third party sensor, but the concepts should still apply.
Also, note that the color sensor will be affected by ambient light.  You could try using a 2nd sensor to factor any ambient light.  What are you trying to accomplish with this application?  Is there a reason you aren't using the Ultrasonic sensor?
(8,611 Views)
Thanks Kyle,
I've followed this link already, with the EOPD sensor, also. My doubt was if I have to apply the same steps to calculate the scale value for the Color Sensor.
The main objective for this experiments is sensor information fusion. So I'm studying what all mindstorms sensors and third party sensors can do.
At the end, I will have to choose the best combination of sensors to achieve a succesfull information fusion.
Thanks for your help!
Best Regards,
Francesc Gómez
Software Engineer
Software Engineer
(8,609 Views)
