LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
New NXT-G block, need some help
Hi Mindstorm...,
what do you wanna see and where? From where do you call this vi?
Mike
Message 11 of 28
(5,551 Views)
I want it to tell the robot how fast the motors are moving, on a rank of 0 to 100 (0 = 0, and 100 = 8.5, if you are testing every 10ms). The SubVI is being called from speed_test.vi, which is on another post. It (should) run the motor forever, and display the speed.
Message 12 of 28
(5,547 Views)
Hi MindstormsKid,
in your speed_test.vi is no loop, so it don´t run forever. Your while loops in the sub vi will never stop. Please explain where and what you wanna show.
Mike
Message 13 of 28
(5,535 Views)
I saw what you meant, and changed them both. It now sorta works. But first:
I'll explain EXACTLY what I want:
First, I tested a motor, that had the max possible amps. I found that it does about 850 degrees in one second of the motor running at 100 power (I used NXT-G). I wanted to make a block that could tell me how fast the motors were running, based on how many rotations there were every 10ms.
Ok, that's all. I made a new version of both, and now it sort of works. The number it displays is between 25 and 30 in my tests (it should be 95-100). Part of that problem was that it won't allow numbers with decimals in them on the NXT. Any idea on how that can be fixed? And even if it was 8.5, it wouln't get the number to 90.
Message 14 of 28
(5,531 Views)
Hi MindstormsKid,
to fix it you can calcualte with 80 instead of 8 and change only the view. Make all internal calculations with integers. Why do you connect 0,1,3 to the ports? If you want to use numbers, then Port C is 2 instead of 3.
Mike
Message 15 of 28
(5,525 Views)
Ok, now it works, but when I set it to 85 on the SubVI, and 100ms wait on speed_test.vi, it will display a number before and after the speed.
Message 16 of 28
(5,523 Views)
Hi MindstormsKid,
what do you mean with before and after? It can only show it ones per iteration.
Mike
Message 17 of 28
(5,521 Views)
I meant on the NXT's screen (e.g. 6970, where 97 is the speed).
Message 18 of 28
(5,519 Views)
Hi MindstormsKid,
ok, i understand what you mean, but 697 is what you, right?  And because you know that it is 10 times more you can cut the string acording to it.
Hope it helps.
Mike
Message 19 of 28
(5,507 Views)
No, I wanted it to display 97, so I divided it by 100. It now does everything correctly. However, every time I download it, it gives me a warning because the divided value is floating-point. Also, it resets the rotation sensor every every time it runs, so it will mess up some programs. Is there any way to not use this (e.g. using math)?
Message 20 of 28
(5,505 Views)
