LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
New NXT-G block, need some help
Sorry, forgot the attachment:
Message 21 of 28
(5,092 Views)
Hi MindstormsKid,
why do you want to display 97? I thought you have 0 to 100 as input and you want 0 to 850 as output! Isn´t it correct? How do you get the 697?
Don´t use the divide function. As i said before, calculate only with integers and if you want to display something you can use the string subset function, to get only a part of it.
Mike
Message Edited by MikeS81 on 07-18-2008 09:31 AM
Message 22 of 28
(5,089 Views)
No, I wanted it to take the number of degrees the motor spins every 100ms, and put out a numeric value from 0 to 100. There is a motor power block that tells how much power the motor is getting, but no block that tells how fast the motors are turning.
Message 23 of 28
(5,084 Views)
Hi MindstormsKid,
what about this solution? You read the current degree value and store it in a shift register, so you can calculate the difference between the last and the actual position.
Hope it helps.
Mike
Message 24 of 28
(5,074 Views)
Sorry for the delay, I'm still testing it. There might be a problem...
Message 25 of 28
(5,045 Views)
Hi MindstromsKid,
can you explain your problem, please?
Mike
Message 26 of 28
(5,042 Views)
Mike, sorry about the delay. I've started building a new robot that's taking all my time. I'll continue testing when I'm done with it.
Message 27 of 28
(4,968 Views)
Sorry about the long wait, Mike, but I've been very busy 😞
I think the problem was that I had been changing your code a little bit, but I changed it back so now it works fine. One question... How does it (the new one) work? Even if I hold the motor still or at around 50% power, it still says "0" or "50". Thanks.
Message 28 of 28
(4,697 Views)
