LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Sample time? (read sonar halts)
I have a very simple program, that reads the distance from the Sonar-sensor. If the distance is above 20 cm, the motors A and B will turn backwards until the distance is above 20 cm.
This works just fine in debugging-mode, but not when the program is targeted to the NXT itself. I think this has to be something about sampletimes? I can add a Wait for 200 ms" and its get bettet. But there must be some kind of documentation about this?
Any thoughts is appriciated.
Regards, Alex.
(6,807 Views)
Hi Alex
It should not be nessasary with a wait function.
Could you please check if the following example program works on your device:
Help --> Find examples --> Directory Structure --> NXT Robotics --> Motors --> Case_Structure_Motor_Control.vit
It has approximately the same structure as your application.
Best Regards,
Anders Rohde
National Instruments Denmark
(6,798 Views)
Hi Anders.
Thank you for your reply.
The example program works just fine. It could seems like the Read Sonar is different than the other Read sensor? I found another guy with the exact same problem:
http://stackoverflow.com/questions/8404029/why-does-this-program-work-in-labview-when-targeted-to-co...
Regards, Alex.
(6,792 Views)
Anyone?
(6,771 Views)
Hi Alex
What version of the NXT module are you running?
(6,758 Views)
I'm using LabVIEW 2011 with the LabVIEW NXT Module 2011.
Downloaded from:
http://joule.ni.com/nidu/cds/view/p/id/2637/lang/en
(6,754 Views)
