LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Superscripts in Properties boxes
I'd like to use a superscript notation instead of m/s/s for the units of acceleration in a Properties box in order to provide a label with units alongside a numerical indicator.  I've tried doing a cut and paste from a word processor but the paste is not available. Any ideas of how it might be done would be appreciated.
(6,251 Views)
Accepted by Yorky_Bar_Kid
You could use the ascii ALT codes to add the characters; ALT+0175 followed by ALT+0178 should produce ¯².
If you do this in word, then CTRL+C to copy, then CTRL+V to paste in LabVIEW it should look a bit neater ¯².
Stephen C
(6,242 Views)
Thanks Stephen, using the CTRL+C and CTRL+V in Word you suggested as that is easy for students (and me) to use.  So your solution has solved both the m/s/s and the deg C problem that I had that look better using superscripts.
(6,234 Views)
