LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Where are the NXT Native VI's located in Labview 2013?
In past versions of Labview such as Labview 2009, I have used the NXT_Calibration.vi that used to be located in the following tool palette
Functions - NXT Programming - NXT I/O - NXT Native I/O - NXT_Calibration.vi.
Our school has upgraded to Labview 2013 and the Functions - NXT Programming - NXT I/O palette no longer exists.
Can these Native Tools be downloaded from somewhere?
Alternately is there a new Vi for calibrating the NXT light sensor?
(6,689 Views)
Hi jbw,
It sounds like you don't have the NXT module installed.  Here is the download for that module:
http://www.ni.com/download/labview-nxt-module-2013/4050/en/
Nick
Applications Engineer
(6,669 Views)
Hi jbw,
The Native I/O palette was removed after 2009, so the functions used to interact with the light sensor will generally be the ones on the NXT I/O palette.
The NXT_Calibration.vi can still be found on disk at <LabVIEW>\vi.lib\NXT\Remote Library\Calibration\NXT_Calibration.vi where <LabVIEW> is the path of your installation (C:\Program Files\National Instruments\LabVIEW 2013 by default.
Keep in mind that these VIs are from the original toolkit and will only execute in Remote Mode.
Cheers,
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(6,626 Views)
