LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
labview and nxt
NI工程師你好,我是frddomcanopy
             對於網路上的Labview and Nxt 有點看不懂,想直接請問妳們以下問題
1. Labview8.5連結Nxt介面是否需要某個軟體相連接嗎??
2. 是否可介紹怎樣寫入Nxt嗎??
謝謝
(6,750 Views)
Hi freedomca,
can you write in english please? You can check the connection if you use the vi´s to search for a connected NXT.
Hope it helps.
Mike
(6,747 Views)
Hello frddomcanopy,
You need to install LabVIEW NXT Toolkit so that you can work with NXT using LabVIEW. Once you get NXT Toolkit installed successfully, you can then launch the NXT terminal from LabVIEW menu bar Tools>>NXT Module>>NXT Termial. Using this terminal you will be able to send files to NXT.
-Nan
(6,608 Views)
